Run Time: 0.000734
-- XFDB=fromWrite
SELECT session_data
FROM xf_session
WHERE session_id = ?
AND expiry_date >= ?
Params: MHe0BTOWpEx6FzlmjtIIXcT5OZKQVxkj, 1716453316
Run Time: 0.000267
- XF\Db\AbstractAdapter->fetchOne() in src/XF/Session/DbStorage.php at line 30
- XF\Session\DbStorage->getSession() in src/XF/Session/Session.php at line 55
- XF\Session\Session->start() in src/XF/App.php at line 897
- XF\App->XF\{closure}() in src/XF/Container.php at line 31
- XF\Container->offsetGet() in src/XF/Pub/App.php at line 47
- XF\Pub\App->XF\Pub\{closure}() in src/XF/Container.php at line 31
- XF\Container->offsetGet() in src/XF/App.php at line 2694
- XF\App->session() in src/XF/Pub/App.php at line 152
- XF\Pub\App->start() in src/XF/App.php at line 2349
Run Time: 0.000236
WHERE (`xf_thread`.`thread_id` = '48377')
Run Time: 0.000802
WHERE (`xf_post`.`thread_id` = 48377) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002083
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 48377
Run Time: 0.000148
Params: 0,
Run Time: 0.000185
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=48377, 1716453316, , 0,
Run Time: 0.000200
WHERE (`xf_session_activity`.`user_id` = 53147) AND (`xf_session_activity`.`unique_key` = '53147')
Run Time: 0.000180
WHERE (`xf_thread_reply_ban`.`thread_id` = 48377) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000212
Run Time: 0.000206
INSERT INTO xf_session
(session_id, session_data, expiry_date)
session_data = VALUES(session_data),
expiry_date = VALUES(expiry_date)
Params: MHe0BTOWpEx6FzlmjtIIXcT5OZKQVxkj, , 1716467716
Run Time: 0.000205
- XF\Db\AbstractAdapter->query() in src/XF/Session/DbStorage.php at line 57
- XF\Session\DbStorage->writeSession() in src/XF/Session/Session.php at line 221
- XF\Session\Session->save() in src/XF/Pub/App.php at line 462
- XF\Pub\App->complete() in src/XF/App.php at line 2356
bytes_sent | 10553 |
bytes_received | 270001 |
packets_sent | 124 |
packets_received | 891 |
protocol_overhead_in | 3564 |
protocol_overhead_out | 496 |
bytes_received_rset_row_packet | 181 |
bytes_received_prepare_response_packet | 54099 |
bytes_received_change_user_packet | 214834 |
packets_sent_command | 61 |
packets_received_prepare_response | 717 |
packets_received_change_user | 88 |
result_set_queries | 17 |
non_result_set_queries | 5 |
ps_buffered_sets | 17 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 119 |
proto_binary_fetched_short | 172 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 456 |
proto_binary_fetched_json | 403 |
proto_binary_fetched_blob | 197 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 213495 |
