Run Time: 0.000610
Run Time: 0.000234
WHERE (`xf_thread`.`thread_id` = '34237')
Run Time: 0.000731
WHERE (`xf_post`.`thread_id` = 34237) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 20) AND (`xf_post`.`position` < 40)
Run Time: 0.001730
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 7 | Using index condition; Using where; Using filesort |
Params: 34237
Run Time: 0.000122
Params: 0,
Run Time: 0.000186
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=34237&page=2, 1716461526, , 0,
Run Time: 0.000199
WHERE (`xf_thread_reply_ban`.`thread_id` = 34237) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000207
Run Time: 0.000187
bytes_sent | 9357 |
bytes_received | 261990 |
packets_sent | 100 |
packets_received | 823 |
protocol_overhead_in | 3292 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 155 |
bytes_received_prepare_response_packet | 51458 |
bytes_received_change_user_packet | 209641 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 672 |
packets_received_change_user | 81 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_fetched_from_server_ps | 67 |
rows_buffered_from_client_ps | 67 |
rows_skipped_ps | 67 |
proto_binary_fetched_bit | 49 |
proto_binary_fetched_short | 143 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 377 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 388 |
proto_binary_fetched_blob | 164 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 208405 |
