Run Time: 0.000618
Run Time: 0.000124
WHERE (`xf_thread`.`thread_id` = '48232')
Run Time: 0.000562
WHERE (`xf_post`.`thread_id` = 48232) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002765
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 48232
Run Time: 0.000088
Params: 0,
Run Time: 0.000138
WHERE (`xf_session_activity`.`user_id` = 52976) AND (`xf_session_activity`.`unique_key` = '52976')
Run Time: 0.000234
WHERE (`xf_thread_reply_ban`.`thread_id` = 48232) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000201
SELECT `xf_unfurl_result`.*
FROM `xf_unfurl_result`
WHERE (`xf_unfurl_result`.`url_hash` = 'afc6610ef4a2b052f7d5de435b366925')
Run Time: 0.000446
SIMPLE | xf_unfurl_result | const | url_hash | url_hash | 34 | const | 1 | |
- XF\Mvc\Entity\Finder->fetchOne() in src/XF/Repository/Unfurl.php at line 67
- XF\Repository\Unfurl->getUnfurlResultByUrl() in src/XF/BbCode/Renderer/Html.php at line 1504
- XF\BbCode\Renderer\Html->getUnfurlResultFromUrl() in src/XF/BbCode/Renderer/Html.php at line 1481
- XF\BbCode\Renderer\Html->getRenderedUnfurl() in src/XF/BbCode/Renderer/Html.php at line 1394
- XF\BbCode\Renderer\Html->renderTagUrl() in src/addons/Tapatalk/XF/BbCode/Renderer/Html.php at line 239
- Tapatalk\XF\BbCode\Renderer\Html->renderTagUrl() in src/XF/BbCode/Renderer/Html.php at line 310
- XF\BbCode\Renderer\Html->renderTag() in src/XF/BbCode/Traverser.php at line 63
- XF\BbCode\Traverser->renderSubTree() in src/XF/BbCode/Traverser.php at line 39
- XF\BbCode\Traverser->renderAst() in src/XF/BbCode/Traverser.php at line 22
- XF\BbCode\Traverser->render() in src/XF/SubContainer/BbCode.php at line 222
- XF\SubContainer\BbCode->render() in src/XF/Template/Templater.php at line 2387
- XF\Template\Templater->fnBbCode() in src/XF/Template/Templater.php at line 1128
- XF\Template\Templater->func() in internal_data/code_cache/templates/l1/s2/public/post_macros.php at line 429
- XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l1/s2/public/post_macros.php at line 59
- XF\Template\Templater->renderExtension() in internal_data/code_cache/templates/l1/s2/public/post_macros.php at line 93
- XF\Template\Templater->renderExtension() in internal_data/code_cache/templates/l1/s2/public/post_macros.php at line 122
Run Time: 0.000175
bytes_sent | 9870 |
bytes_received | 274565 |
packets_sent | 118 |
packets_received | 914 |
protocol_overhead_in | 3656 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 55955 |
bytes_received_change_user_packet | 217620 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 741 |
packets_received_change_user | 90 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 72 |
rows_buffered_from_client_ps | 72 |
rows_skipped_ps | 72 |
proto_binary_fetched_bit | 91 |
proto_binary_fetched_short | 176 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 467 |
proto_binary_fetched_decimal | 20 |
proto_binary_fetched_json | 434 |
proto_binary_fetched_blob | 197 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 216236 |
